Recall on '97 and '98 trucks
MadFish
Dont know if anyone has posted this yet. But, I got a recall notice on my truck today.
Its for 1997 Blazers and Suburbans, 1998 C\K Extended Cab trucks, Astro Vans, and Suburbans equipped with electir outside rearview mirrors.
