15 Silverado speaker and amp help
Jeff5347
Hopefully someone can guide me in the right direction. I'll try to make this as easy to read and follow as possible. I have a set of pioneer http://www.sonicelectronix.com/item_22430_Pioneer-TS-D1702R.html for the front doors and pioneer http://www.sonicelectronix.com/item_11269_Pioneer-TS-D1602R.html for the rear doors and will be adding a http://www.sonicelectronix.com/item_93408_JL-Audio-ACS110LG-TW1.html for my sub. I will be keeping the factory non Bose radio. Here's some of my questions. The door speakers are rated at 60 watts RMS.
1. Would u still amp the speakers or would you be able to get away with just the head unit power? As it stands now the stock radio is fairly low in the volume area. At say 3/4 volume it is just getting load. Not looking to be heard down the street I just want some wiggle room to play with so I can get loud say on the highway w the windows down.
2. If I run a 4 CH amp that pushes less wattage, say 45-50 will all be OK. I was looking at the pioneer gm a6604 and it is reasonably price but just looking to keep final build price low.
The other question is if amping the speakers and still using the stock hu, the pioneer amp has speaker level inputs. Again I'm not looking to go all out so would using the speaker level inputs be OK. I wouldnt need to run a remote wire as the amp is signal sensing off the speaker level inputs. Would this be significantly less quality than RCA's. I would think unless I put an AM hu its a mute point since I still would need to run speaker levels to a LOC.
With the the powered sub I would just splice into the front left or right speaker wires to get a signal. This sub is also signal sensing so a remote wire is not needed.
I've installed many speakers and hu in my previous cars but always replaced the hu so RCA's were always used and wiring was straight forward. Now with everything integrated into everything it gets a bit tougher.
Sent from my Nexus 6P using Tapatalk
  • 3 weeks later...
Everything you said should be just fine. With regards to the sub, you're going to want to use both front left AND right channels as some songs may have a split stereo bass part. I agree, the stock amplification is fairly quiet with aftermarket gear (I personally run Rockford Fosgate Punch series speakers in mine). Using a 4 channel amp shouldn't cause you issues, but bear in mind that you may have to use filtration to account for alternator whine.
Thanks man. I installed the rear coaxials already and they are super quiet. I have the front components and the PPI amp, speedwire, local and stuff will be in on Monday. I have one of the metra connectors now just waiting on installer.com to get off their butt and get the other one in the mail. The jl sealed sub is installed tapped into the l and r front speakers and she does pound but I am looking maybe in the spring lifting the rear seat to get a custom box and get 2 10s in. I honestly can't wait to get the amp in to see the difference in sound quality from the doors!
That's great. My rears are quiet too,but that's mainly because it's a standard cab and they were intentionally volume limited from the factory. I have Fosgate Punch component speakers and a 10" Fosgate sub (sealed box) powered by a bridged 2 channel Fosgate Punch amp. It sounds great. I'm glad you're happy with it!
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 423 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
