Fuel filter upgrade?
  • 5 months later...
The fuel filter is part of the pump unit in the tank. Most people replace the pump and filter at the same time (makes sense). I would think you can add an in-line filter if you need the extra protection...
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
