Going left
When is the last time you had the alignment checked? Were any of the tires worn unevenly? Possibly a brake getting hung up? I'd start checking everything on the suspension.
Let us know once you confirm the problem.
Apparently I might have a bad tire because both front tires have obvious signs of dry rot starting.
Sent from my HTC6535LVW using Tapatalk
