Projector headlight questions
Hi all,
Trying to get suggestions on who makes the best quality projector headlights but also look the closest to stock units? I have a 2012 gmc denali and want to keep it as stock looking as possible but need more light. I do not want to drop in a HID kit and blind on coming traffic. Are LED's an option here? or do they scatter and blind as well? Thanks in advance, Brian
    Brendan C
    Brendan C
  • Who's Online   1 Member, 0 Anonymous, 1,065 Guests (See full list)
