I'm going to be running 2.5 level with 285/75r17 toyo at2 or cooper at3 (I want the toyo but the coopers are cheaper and way abkut 10 pounds less per tires) with fuel boost 17x9 4.75 back spacing with 0 offset
my tires are 285/70.. sorry I didn't catch that in the beginning. I will be switching to 35s when these wear down a bit more though. yes, I will have to cut.
Cool, good luck.
What rims and offset and width, that will play into it as well.
That first pic looks a little nose high, is the rear on stock blocks or raised too? Might just be the angle.
I took the blocks out, its a little nose high but nothing too aggressive...
I have the Readylift 2.25" with Method NV 17x8.5 0 offset and 285/70/17 Duratracs. Only a very very slight graze of the felt wheel liner in reverse at full lock. With 2.5" you will be fine.
Thanks! We will find out next Tuesday!
Shit fits
Pics!
Sent from Tapatalk App - Samsung S6
I think you're going to need a bit more than then 2.5" level to run 33.8 (~34") tire. I could be wrong though.
I'm running a 285/75/17 on 17x8.5 0 offset, and I have a fabtec 2 inch level. Very small rub in reverse. Could probably pull the liner back a bit and it wouldn't rub.
You'll have a slight rub in reverse at full lock... Nothing to worry about.
8C8A8C61-2DDE-486A-9096-9A33F66334AF_zps
What wheels are you running?
Here is mine. 2 inch fabtec leveling kit, 285/75/17 toyo open country extream a/t mounted on 17x8.5 vision manx 0 offset wheels.
robby gordon
robby gordon
Those look good on there!
Thanks, not a fan of the tires, but I got a smoking deal on them via Craigslist. Waiting for them to wear a little more before I switch back to toyos. Your setup looks sharp
Thanks! Might get different wheels, but they were what I had on my 2008 sierra. I put them on so I wasn't rolling on stock wheels.
Here's another pic
it won't let me upload it on my phone
You have to put your photos on photobucket, and then copy and paste the link for online forums.
    Whit.the.COB
    Whit.the.COB
  • Who's Online   3 Members, 0 Anonymous, 1,251 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
