Hello All
EMC'S Z
Hello.  I just got a 97 GMC 1500 Ext Cab 4x4 W/ a 350.  This seems like a good place to help me get my truck just how I want it.  I have a lot of plans for this truck.  First off is a new Stereo.  The stock sounds like AM talk radio. :chevy:
Hello.  I just got a 97 GMC 1500 Ext Cab 4x4 W/ a 350.  This seems like a good place to help me get my truck just how I want it.  I have a lot of plans for this truck.  First off is a new Stereo.  The stock sounds like AM talk radio. :eek:
Nice to see you got the best body style ever put out by this company . :thumb:
Hello.  I just got a 97 GMC 1500 Ext Cab 4x4 W/ a 350.  This seems like a good place to help me get my truck just how I want it.  I have a lot of plans for this truck.  First off is a new Stereo.  The stock sounds like AM talk radio. :seeya:
:eek:  :seeya:  :seeya:
Welcome. :eek:  Let's see some pics.
It has been Raining Every day here. I havent taken any pics yet because Right now the truck is Covered in mud. (+ 2"-3" mud on the ground where I park.)  I was hoping to get it washed and waxed yesterday but It started raining at about 1:00pm.   Where can I host Pics from?  Is there a place in this sight?
Thanks Everybody.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
