led light bar come on when high beam is activated
Ok,looked it up it said it is for the use of high and low beams,do you think my light would stay on all the time?,i am wanting it to come on with the high beam and go off with the low,so what do ya think? should it work that way with the high beam splitter?, ,
,thanks for the help
I got my 30" light bar wired into my high beams. I really didn't want to mess any thing up and i wasn't sure where to tap in so i had the dealer do it. The dealer tapped into the high beam wire just past the plug that connects into the BCM under the dash by the OBD port. They mounted the relay just inside the side access panel for the dash on the driver side so that it is fully protected from the weather. Check out the 1st page in the link below(also a good mod if you haven't done so already!) for referencing the proper wire to use to tap into as the link has pictures. I believe its PIN 18 on the brown connector.
http://www.gm-trucks.com/forums/topic/162734-foglights-on-with-high-beams/
By the way, i was debating to just run it on a manual switch like i have always on my past trucks but im so happy have done it this way!
the highbeam spitter didnt work,,,my truck lights has the lights that stay on high all the time,,it has the flapper that comes down over them that reduces them to low beams,,,,,,,,now my question is to mad matt,,,if i use the 18 pin wire for my signal would that trigger my relay to do what i need it to do,,,thanks
Yes it would seem that way. It looks like the dealer used the high beam pin as the trigger for the relay.
Like I mentioned I did the fog light with high beam mod that uses that exact pin and my fogs don't stay on with my DRL's(my truck is a SLE so it also uses the Headlight bulb as the DRL). They only come on with high beams so that pin must be powered separately from the DRL.
Just wire the switch inline with the feed from the high beam. I've run rigs this way in the past and it works well, as you may not want to always have the LED running with the high beams.
    DaleB
    DaleB
  • Who's Online   2 Members, 0 Anonymous, 1,246 Guests (See full list)
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
