Lighting Mess
Driver brake light doesn't work
Both rear turn signals don't work
Everything is operational
Fuses are good
Any ideas on where to start?
Appreciate it.
Try hazards ( 4 ways)
Check ground wires for lights in bed
Bulbs
Do the 4 ways flash inside the truck?
Front and mirrors work with hazards.
The indicator stays illuminated in the cab when signaling. Flashes when hazards are on.
Bulbs replaced.
Replaced the relay as well under steering column.
I guess I'll start checking out connections. I've done a lot of different work with my vehicles. Electrical was never my strong point haha
Trailer lights are completely operational.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,155 Guests (See full list)
