2009 silverado cruise control switch swap question
Hello: I have a 2009 silverado that I need to change the cruise control switch due to it stopped working. I have the new switch but my question is how do I remove the old one to install the new one? I know I need to remove a trim piece off the steering wheel but when I go to it seems like I may break it so what is the correct way to remove it?
You need to...
- Disable the supplemental inflatable restraint (SIR) system. Remove the negative batt. cable.
- Remove the steering wheel airbag. On the back side of the steering wheel, there are 2 access holes. Using a 3–4 mm T handle allen wrench, insert in a cross car (Horizontally) direction and slightly outboard (handle towards I/P) push in 40mm (1 1/2 in) to engage release spring.
- Remove the horn switch (4 screws) and they appear to hold the two trim pieces down to the steering wheel.
- Remove your switches, then reverse the order of disassemble!
    appletrav
    appletrav
  • Who's Online   4 Members, 0 Anonymous, 281 Guests (See full list)
