The Retrofit Source 2014 Silverado Spec Kit
Guys,
I received my kit yesterday in the mail and I'm gearing up to install this weekend. My first impression of the kit is that it's well built.
After watching some videos and reading on here I have some questions.
1. I was given some extra cords in the box as seen in the below picture. The cable at the bottom is the capacitor and will plug to my OEM cord (top) and I only need to do that for once correct?
What are the other cords for?
2. For the OEM plug in, the connector are not pre-made. I am given the material to make a plug using the black and red wire, the orange rubber caps and I would slide them into the plug but on the videos this seems to have already been done. Have others experience this?
Thank you for the help in advance. I'm super excited to get this on my truck but I want to make sure I get it right the first time. Any help or tips would be awesome.
You're missing pieces partner, Is that everything they sent you? Where is the relay and the other head light adapter? Do you have more parts or is that it? Snap a picture of everything you got and I'll walk you through the install. Being that you're doing a chevy and not a GMC I think you'll use most everything you got there. One question during the day time do the low beam head lights function as your day time running lights?
Guys,
My headlight pigtails came pre assembled but I took them apart to fish them through the hole you have to drill in the dust cap so don't put them together until the holes are drilled and the wires are fished through.
Thanks for the info. I installed the kit today and it's incredible. The light output is so much better than the stock. I can finally see good at night.
U should swap out the projectors for some fxr the kit is 3x improvement over stock projectors are 10x better
    B07
    B07
  • Who's Online   0 Members, 0 Anonymous, 933 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
