Firestone Ride Rite for a 2014
For the 14 Silverado, is the part number 2430? Hard to believe not changed from the previous body.
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 1,373 Guests (See full list)
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
