Tire squeal in Right turns
B33tl3
I have something weird going on. When I make right hand turns like at a T intersection my right rear tire squeals a little bit. It's like a locked rear diff on an old truck. I am not getting on the gas hard and it even does it in parking lots. The tires are all terrains with lots of tread. Any ideas? Gas milage has gone down a good bit to but not sure if it is related.
2014 Sierra SLT 4X4 Crew cab
jsut hit 30K Saturday.
