UPD Installed
Installed today, besides the big sucking sound under the hood, I don't feel much SOTP.
Does the computer have to re-learn? If so, what time frame am I looking at.
Right now, it feels like I have lost some low end torque actually, it kicks at 55mph now, and not 45mph.
Am I crazy? :)
