Flex fuel pressure
Slo2type2u
Hi.. I have the wonderful P0172 and P0175 codes together.. Both banks rich... Changed the MAF and MAP sensors.. Looked for and didn't find any vacuum leaks.. I looked at the fuel pressure and it's 56(KOEO) and around 60 at idle.. I have a Flex fuel (2006) engine... The pressures I'm seeing are in spec for the regular gas engine but I read the flex fuel engine is supposed to be 46-52..could the previous owner have put the wrong fuel pump in as a replacement and caused this rich condition?
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
