2000 gmc 1500 a/c compressor replacement
Hey guys new here. did a search but couldnt find an answer to my question.
Can the a/c compressor be removed through the passenger side wheel well? it looks like it would be able to. I just ordered a replacement online and wanted to know before i started pulling it apart.
thanks in advance.
I removed the fan shroud and pulled it up through the top.
Helpful hint: you can remove both back and the front top mounting bolts, you can NOT remove the front bottom bolt. Leave it in the compressor on the trip out, and put it in the new compressor before lowering it back into place.
Tip: Replace the tensioner pulley while you have it apart. I'd just replaced my compressor and clutch and less than a week later (in the middle of the HOT summer), the tensioner pulley seized, snapping the belt and leaving me without A/C on a hot road trip up to Wisconsin.
    hotfish
    hotfish
  • Who's Online   6 Members, 0 Anonymous, 659 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
