Magnaflow 15318
AaronIROCZ
Anybody have any long term experience with this kit?? Right now I have had mine for around 1 year and 9 months and something broke I am assuming inside of the muffler as it now sounds like a hallowed out tin can with marbles floating around inside of it. Every time I step into the throttle 1/2 way or more I get this sound that to me sounds like complete crap. I have contacted Magnaflow about this and as of 3 weeks later I have not gotten a single response about it. I had it on my 2014 and swapped it over to my 2016 and the sound remains. I wish I could get a video of this sound but my camera will not pick up the sound. I might try another camera or strap it to the frame to see if it can get it under the truck. Completely frustrating after spending close to 1000.00 on exhaust and it only lasts not even 2 years and the manufacturer doesn't seem to care.
    Fishboat
    Fishboat
  • Who's Online   2 Members, 0 Anonymous, 508 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
