Snake's 2002 Z28 project
SnakeEyeSS
First off, yes it's a car but I've been told on my past go fast toys by people here they enjoyed watching it go along (not sure if they meant the progress or the misery, :lol: ), so I thought I'd make a "one spot" thread here. If it's "not allowed" since it's not a truck, delete it.
I know, some of the stuff I've done and I decide to start a build thread on this :lol:
Bought it with so many miles everything underneath needed attention so the previous owner did some nice upgrades before selling. He had some stuff going on, long story short decided to pick up a low mile car fully loaded and start over(he said it was in great shape but was going to have to replace all the same parts due to age). Paint shows wear but really not that bad for the miles(think it's been repainted since many labels and RPO codes are missing.
A few minutes after purchase. It was pretty dirty inside and under the hood.
So I cleaned it up everywhere, with a NanoSkin treatment and Colinite 845 outside. Aerospace 303 inside. Three old socks gave their lives for the cleaning of this interior.
And a day later the famous common GM socket meltdown occurred.
Here is the mod listas/recent replacement list as purchased:
Strano Springs
Bilstein Shocks(SLP performance suspension spec I think)
Auburn Pro Series Carrier
3.73 gears
New clutch
New flywheel
New spark plugs(NGK Iridium)
New Alternator
New slave cylinder
New Power Steering pump
Moser Engineering 28 spline Axles
New structure assembly components, KYB mounts
New front and rear stabilizer end links
BMR strut brace
BMR tubular upper control arms
Hotchkis adjustable rear panhard bar
IMO rear control arms
BFG Sport Comp 2
New Calipers and Drilled and slotted rotors on front
So I cut it off and soldered on a new one. No pic, so imagine that, just not melted :lol:
5 minutes after cleaning the underbody, the leak the seller suspected was confirmed:
So a few days later I had that fixed, no more leak, so the clutch is safe now
Got in some new door panels from a leather car, they are near mint. Haven't installed, might hold off until AC is fixed.
The steering wheel had a cover because a chunk of the rim was just gone. So I slowly filled in the spot with Gorilla Wood Glue until is was good, than installed this cover. Found a wheel but didn't want to replace a wheel since the wheels are pretty cheap quality, and one for this car is rare to find nice(it's a 1SC/1SZ trim car, stripped/options deleted), might buy it and store it for a later date.
Also will put this on soon
Car has a plate bracket on front, so this will help it look better(OK doesn't require front plates). Might get the Carbon Fiber grille someday later.
Very nice car you have sir. I too had a 2002 Z28 hard top. Pearl blue
Torquer V2 cam 3200 Edge stall long tubes full exhaust custom tune
Miss that car . Seeing you bring this car back to life makes me want to go find me 1[emoji106] [emoji108] [emoji108] [emoji108] [emoji108]
It wasn't on it's death bed, just needs cleaning and work. The PO gave me a good start with the fresh suspension, but I think he hit his limit on replacing stuff on an old car. Probably going to start the Oil pan before long to just get it done. The YouTube videos that show what to disassemble(the black TA video is the best) make it look like it's gonna be rough. Decided to to it myself(or attempt to) since it's 60%+ of what you need to do during an engine swap, and so I figure I could use the experience on The car since I want to do an LS3 swap whenever this engine starts to go(220k miles, but runs good so far) or 2-3 years, whatever comes first. And it looks like a popular way is to drop the K member and subframe out, roll it to the side, swap the engine, then put it back in.
Ls3 are good motors. But those LS1 you can never go wrong with those bad boys,, one thing I hated the most they are really hard to work on. HARD TO REACH places . But your right on doing things your self, It's about the only way you can afford play
Started the oil pan project. Just jacked it up and loosened the wheels is all. Not Rushing it, if I can get off Saturday might have it done over the holiday weekend.
Don't forget to put the nut on the mounting bolt.
:lol: I did, that was just a "I gotta get out from under his friggin thing" break.
Can now add a few things to the list
Energy Suspension Polyurethane:
Motor Mounts
Transmission mount
Sway bar endlinks
(Last two were already there, just not on the list)
Did a seafoam induction cleaning after a test drive, and after the seafoam high RPM drive I could smell crap still smell stuff burning off after I shut it off. Must have been dirty in there. Only running 100% 91 octane gas from a Top Tier station for a while at least, even before I get a tune.
  • 3 weeks later...
Replacing coolant hoses now.
I might take out the EGR and AIR systems and do a tune sometime. AIR system is throwing codes and it's easier to remove and tune than hunt it down.
Hoses arrived and are installed.
Somehow, a gallon jug of distilled water busted open half way and made a half gallon pond in the hatch. I looked back there 2 days ago so it just happened, pulled the carpet up and looked fine, guess it's good it's stupid hot so the carpet will dry fast. Luckily I had a gallon of Prestone "Any Color"(I have read user reports that it does mix fine with Dex, only been out since 2014 or something) and some bottled water to make up the difference.
Funny how I order Camaro hoses from RockAuto and get a magnet of a Mustang in the box.
    Whit.the.COB
    Whit.the.COB
  • Who's Online   1 Member, 0 Anonymous, 1,196 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
