33x12.50 20
I've got a 15 All Terrain with a RC 2" level on the front. I'm sure this subject has been worn out, but I've got access to raw aluminum and a CNC. Curious if I build about a 3/8" spacer if it would be enough to clear everything tire with with a stock 20" wheel? I want it to be hub centric is the only reason I'm considering doing it myself.
I have a 2.5 level in the front and barely rub on full lock with 33.1250.17 mud grapplers
Sent from my XT1254 using Tapatalk
    contrabombarde
    contrabombarde
  • Who's Online   3 Members, 0 Anonymous, 757 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
