4.8 to 6.0 swap
OK so I have a nnbs silverado 2007 z71 4x4 4.8 and I want to know what and how much I would need to do a complete swap to 6.0..my current transmission is a 4L60e
COULD REALLY USE ANY HELP PLEASE
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 705 Guests (See full list)
