Bumper mounted driving lights
https://www.dropbox.com/sh/vaj4v5kksui5dbu/AACUxvgZsaz4mC_MX1uggSBoa?dl=0
Debating using the N-Fab light bar to mount driving lights or could I mount them on the bumper. Mainly concerned about someone backing into the light bar and lamps.
Looked under the bumper to see what clearance there was for drilling, when I was surprised to see GM had made provision for just this situation. In the shared photos you will see 2 x 1/2" holes in the bumper metal. Further, they reinforced the plastic fascia with a box to support around the hole for taking the pressure to tighten the mounting bolts.
For this specific install - PIAA 520 driving lights in yellow for better contrast in the rain, and less back reflection. Had to get 2"x 3/8 bolts as the supplied bolts were a bit short.
Plenty of clearance behind the light for the grill.
Thought this might be good info for anyone else considering same.
  • 4 weeks later...
    Gkistler
    Gkistler
  • Who's Online   6 Members, 0 Anonymous, 921 Guests (See full list)
