2013 GMC 1500 Extended cab, 2wd
I have a 2013 GMC 1500 2wd. I took my truck to our local GMC Dealership in hopes they could resolve this issue. My Dash lights don't work all the time. The Dealer replaced the Sensor on Dash but I still have the problem. It might be a few seconds to perhaps 45 min. before they come on. It doesn't happen ever time I start my truck either. No codes pop up & all gages are working as they should. Anyone else have this problem & found the fix? I'd sure be owing ya if you would share any info.
Thanks
Keith
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 705 Guests (See full list)
