Exhaust smell in cab
I have a 2012 crew cab Sierra and I'm experiencing some exhaust smell in the cab every now and then I noticed it about a month before getting exhaust work done on my truck it was at the dealer for cam and lifters last November and no exhaust smell at that point has anyone else experienced this it is a 5.3 truck
I had that problem last year...I started to smell the exhaust in the cab with the windows all the way up and the doors shut properly. I knew it had to be an exhaust leak pretty far forward to get into the cab so I checked the exhaust manifolds and where they connected to the down pipes. Sure enough the drivers side had a leak where the manifold bolted to the down pipe. I went and bought the gasket and replaced it and the smell was gone.
you still may have an exhaust leak.
    bellssn690
    bellssn690
  • Who's Online   4 Members, 2 Anonymous, 831 Guests (See full list)
