Question for Zone Lift Owners
I have my truck going in next week to install a zone 4.5. I also purchased bilstien 5100s for the front to hopefully improve shock performance. Here is my question. Based on the way my truck sits currently with a 2 inch level I almost still have an inch of rake. Front 39, Rear 39 6/8. The way I am calculating with the size blocks that come with the lift it is still going to keep me close to this much rake after the lift is installed.
My question is should I go ahead and set the 5100s on the 2nd level to hopefully get as close to level. I really want to be as close to level once the level is on and alignment is done. Thanks for any help?
    President Roberto
    President Roberto
  • Who's Online   0 Members, 0 Anonymous, 234 Guests (See full list)
