HawkeyeSierra Posted June 17, 2016 Posted June 17, 2016 Driving home today with A/C on full blast, I thought, "Man, it's getting hot in here." Put my hand by the vents and warm air was coming out. When I got home, I shut the truck off then started it and tried again. Still warm. Called the dealership and made an appt for two days from now. Took my daughter to work, still warm. Tried it again on the way back home, cold again. So now what? If it continues to work, should I still take it in? Have you ever heard of this happening?
Brianibew Posted June 18, 2016 Posted June 18, 2016 If you have a 2014, there is a good chance one of the freon lines split...there are multiple threads on this topic.
HawkeyeSierra Posted June 19, 2016 Author Posted June 19, 2016 If you have a 2014, there is a good chance one of the freon lines split...there are multiple threads on this topic. Mines a 2015. If a freon line split wouldn't the freon all be lost? So how would the A/C begin working again hours later? Anyway, 2 days later and it's still working fine. So I guess I will skip the trip to the dealership. I figured there were other threads. I searched for them and did not find them.
Brianibew Posted June 19, 2016 Posted June 19, 2016 My fault, I didn't see that u said it got cold again.
HawkeyeSierra Posted June 21, 2016 Author Posted June 21, 2016 After working for a couple days, A/C is now back to intermittently. took it in and it was diagnose as stuck open expansion valve and A/C solenoid melting inside the compressor. Replaced both under warranty and so far so good.
