Fabtech 2 inch suspension lift/level
Hey everyone. I created this thread because I can find absolutely nothing on this kit on the web or here. The kit consists of a pair of coil overs, new UCAs and rear shocks. I want to level my 2016 Sierra and would rather not use a spacer, I don't want bad cv angles or ball joint issues. This kit is very expensive, $2500! I'm debating just getting a 4 inch lift for the same price.
Would this be worth the cost over a spacer leveling kit? Or would I be just as well off getting UCAs and using a spacer leveling kit? I just want a kit that doesn't require any cutting or grinding of my factory parts of the truck, which is holding me back on a good 4 inch kit. I had a 2006 Silverado with 35s and a 6 inch BDS kit and I definitely do not want to go near that big. Any thoughts?3df6c5d9d0d1ea71765bd5589f242fa4.jpg
Sent from my treestand using Tapatalk
    Policeoff01
    Policeoff01
  • Who's Online   4 Members, 1 Anonymous, 745 Guests (See full list)
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
