2011 GoRhino body-mounted nerf bars work on 2016?
I have a 2011 Sierra with the GoRhino Dominator 2 nerf bars. These are the body mounted bars that are compatible with body lifts. I plan on purchasing a 2016 Sierra soon and I wanted to put the bars on my new truck. Does anyone know if the mounting points are the same? Are the bars the same length? They have different part numbers on the GoRhino site, but the pics are the exact same and the shipping dimensions are identical.
    zibzer2
    zibzer2
  • Who's Online   4 Members, 0 Anonymous, 739 Guests (See full list)
