Adding power options to 2006 Sierra WT
People don't seem to part these vehicles as much as I want them to. Any websites that I could find some of these final parts on?
Carbon,
I use car-parts.com when I'm looking for used parts. It will list junkyards that have the parts that you're looking for. Once you enter what you're looking for, it will show you the list of places that have your part in stock, and you can sort that list by distance, cost, etc. Good luck to ya!
Jake
  • 3 years later...
On 7/21/2016 at 2:37 PM, Carbon95 said:
Yes I did, but I think the DDM intercepts the signal to the BCM for that function. So until I get that completely connected it probably won't ever detect that the door is open.
Okay. I'm assuming that either a regular battery charger or simply putting jumper cables with another car would work too?
Did you get the truck to read that the door is open, having same problem and wanting to know if you found a solution
    bellssn690
    bellssn690
  • Who's Online   3 Members, 0 Anonymous, 868 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
