Newbie 03 Tahoe Spec. Service Pack
esu78
Hi
Thanks for setting up this board this is great !
I just got an 03 Tahoe Special Service Package (Police Package) custom ordered :confused:
Looking to do some interior work and lighting.... so as I go I will be buggin' you all here and hopefully posting picks !
Thanks for a great resource, lookin fwd to sharing info w/ all of ya
John
How did you do that? I thought only Law Enforcement Agencies could order vehicles like that, or am I missing something?
Welcome to the site. :confused:
Ahh yes the police package are avail to Law Enforcement Agencies & "personnel" only... :lol:
I will be posting pics very soon.
Keep in mind these are basic package no 'toys' really. (no on star/bose stereo)
But it has the 'heavy duty' package suspension/ Larger Air Cleaner/Trans Cooler/ Cool 'Cop' Interior Dome light red/white (red for night)/ Cargo-Barn Doors
5.3 L , 770 Amp Battery all basically the same as the LT/LS. However not pursuit capable :thumbs:
Additional wiring to interior for lighting/radios etc. Fused/Relayed from factory.
Very nice I dont have to fight to do some installs later !
I was able to order /delete options such as full carpeting (not the plastic floors) All cloth seats, Console Delete, and Factory Fog Lamps and adjustable pedals.. ( i know i just think they are cool)
No side molding, Non Tinted Glass.. (but i tinted already how i want)
Pics soon to follow.. let me know if you need more info !
Thanks !
John
Sometimes I wish I had red nighr lights. I hate getting blinded when the passenger turns on that light to se the map or whatever,
I got PICS
Thanks for looking..
And yes the night red light is really cool your eyes dont bug out !
John
2003 Tahoe Special Service
    DaleB
    DaleB
  • Who's Online   4 Members, 0 Anonymous, 1,318 Guests (See full list)
    • Yes that's right, it's the upgrade that includes the overload spring and all that stuff.   Someday when I'm empty and going by a scale I'm going to stop in and get some weight readings.   Exactly  you should have the ability to change individual settings, in in Canada so I'm driving with kph but then I'm stuck with kpa when I want psi lol
    • You must have that upgraded gvw package which is only available or at least was in 2025 with the diesel engine for the 3/4 ton and that gave the truck physically the larger 12.0 ring gear rear diff and the 3500 rear spring pack. There is a difference in what the diff housing looks like externally as one tell tale and also your truck should have the upper overload spring pack and the frame pads that the pack goes up against.    The pressure the tpms system kicks the alarm in on a stock setting truck, that is a good question and was just from what I recall but I doubt I made any notes on it as I knew for the rear that it was not at all what I was after regardless either. Being that you have a diesel and if running on stock tires the minimum pressure on an empty truck seems to be around 50 psi from hearing of those that have weighted the front axle but the rear axle is very similar in weight to a gas truck and again a near empty truck on the rear could go down to 35 pounds at minimum. However the weigh scale is the proper way to know for sure as a guide.    As to changing the readings on the dash from metric to the US measuring system, oh yes that is done easily but what I was attempting to explain was that I can't pick and choose items I want to have in US and those I still want in the metric system at the same time as its either all or none. For example lets say you drove into Canada and switched your dash over to metric so your speedometer read in km an hour, well then your reading kilopascals on your tpms readout and your wife looks over and says what the hell is that saying in the tpms screen and you say "darned if I know, I think its Chinese" !
    • This is partly why I decided to have switched over to Amsoil SS as a way of hopefully preventing the buildup of the sludge/carbon on the pistons and clogging of the oil control rings and the carbon that would cause the compression rings to stick in their grooves as well as stay cleaner up top of the heads in the valve train in the first place, an oil that has tested better by third party testing over typical shelf oil and also doing my best to run relatively short OCI. However in saying that I don't think there is any way to easily prove the oil I was using prior allowed for a buildup at the OCI I was doing, nor in the other direction to make claims the Amsoil is keeping everything clean either. There really isn't a window into the engine is there to know anything for certain even if oil samples were taken for example that showed still healthy oil being dropped out of the oil pan other than engine tear downs that extensive and expensive testing of oils does to actually visually see what is really going on inside the engine. I wish there was some easy method of seeing what is going on but I don't happen to be aware of that if there is.
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
