Helping out a friend...
Sarah99GXE
I went on GM Cars.com but didn't find much. A friend of mine has a 2002 Impala and she wants a Billet Grill. Not sure where to go online for this.
Anyone got any ideas?
Thanks!
I looked around a little and saw them for the 99-01 models, but I didn't see any for the '02s and newer.
Good Luck with your search... :lol:
Yeah I have one on my car and she loves it now she wants one on her impala. I emailed Trenz and they told me their vendor - Stylin Concepts (thanks ShadowFax).
