Tuning 2014-2016 trucks with LSEdit. Anyone else using this?
Looking for anyone else using LSEdit to tune these trucks. Any problems you've ran into. Can't get it to change tire size for some reason. Tried to add a few degrees of timing and then engine wouldn't even turn over. Had to put stock tune back in. Weirdest thing ever.
