Biggest tire for 5" rough country lift
z71truck82
Will depend on wheel size and offset. You will rub with a 35" tire for sure but may be able to get away with something like a 285/75r17 that is just under that. I'm lifted 6.5" more or less in the front and I had to cut to fit my 35s on a 17x8.5 0 offset wheel
    bellssn690
    bellssn690
  • Who's Online   3 Members, 0 Anonymous, 905 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
