Who runs fuel, xd, etc in winter
LTeddy
Hey folks I'm getting my set of fuel mavericks next week and I'm wondering who on here runs theirs in the winter.. I'm wondering if I could run mine in winter or if the painted wheel won't hold up to the harsh conditions.. If you do, do you put anything special on them to keep them from getting corroded or destruction? Much appreciated guys thanks in advance!!
Sent from my SM-G928V using Tapatalk
I've had the same set of black and milled Mavericks on my truck the last two years with no problems.
Did you put any kind of protectant on them?
I do not have those wheels but I do coat my bare polished aluminum wheels with white Lithium grease. These wheels do not even have a clear coat on them and they have survived at least 5 Ohio Winters so far. I just pressure wash them off in the Spring.
Ive had 2 sets a fuels. I had sone fuel hostages that were ruined after two winters but the fuel kranks I have now have been good from this past winter. Key is to clean them often. I probably cleaned mine once a week in the winter months.
I still have my factory ones I'm just trying to avoid buying new tires and be able to run my bfgs year round
You should be fine. If you have a good place to clean them often that is best. What I do is use a pump sprayer used for weed killer and just fill it up with water then wet the wheels then spray wheel cleaner on the scrub with a brush then spray off with the water.
You are a genius!!!!
I guess I learned the hard way with the first set so I had to come up with some idea. But so far so good with them through this past winter
    appletrav
    appletrav
  • Who's Online   1 Member, 0 Anonymous, 483 Guests (See full list)
