2001 Silverado AC stuck on heat
2001 Silverado 5.3. Compressor comes on and stays on. The line going from the compressor to the drier is ice cold and so is the high side line. AC worked fine last summer, heat worked great all winter and now it won't blow cold air. Any suggestions ? I don't have any gauges but can get some if need be.
The blend door is probably stuck.
Either the actuator is bad or the door is physically stuck.
By verifying the compressor is operating and the lines are cold rules out the A/C pressure system is at fault.
The blend door actuator going bad is pretty common and not that bad of a job to repair.
Is the vent/floor/dash blowing as set/expected?
Yes you can change it to defrost,foot,etc... Is there a way to manually move the blend door ? Also a friend suggested the ac controls could be bad (as in the switch that changes it from hot to cold ). If so is there a way to test that ?
I have never found a failed control unit other than flat out failed. As in none of the functions other than fan speed worked.
Testing is pretty much getting to the blend door actuator, and testing for voltage. If you are going that far, pull the actuator, check the door for non-binding operation. If the door is cool and you have voltage at the connector for the actuator motor, then, the actuator motor is bad.
Pretty common for the motor to be bad.
https://www.rockauto.com/en/catalog/chevrolet,2001,silverado+1500,5.3l+v8,1371507,heat+&+air+conditioning,heater+blend+door+actuator,10721
I have used the doorman part on half a dozen of these generation trucks with no comebacks/issues.
My 03 did the same thing. Took it to the dealer and they said it was the actuator. Died in the middle of summer.
Thank you the help is greatly appreciated. I will have to check it in the next couple of days.
I personally would buy the actuator and have it on hand when you get to checking it.
If that door is binding, you will have do go deep in the dash to fix it. At that point, replacing the actuator makes sense as if the door is binding (not a common problem) that actuator is gonna fail soon anyway. They fail with a perfectly fine working door often enough...
Hi, new member here. I just had this same problem, we're going to try and fix it Sunday... any advice as to how to get to the actuator? We've already replaced the blower motor module because the fan speeds weren't working. Thanks!
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
