Intellilink Observation....
This may be old news and a "duhhh", but I just figured it out... BY ACCIDENT...
If my phone is connected via bluetooth (not wired connection), I discovered a LONNG press of the steering wheel button invokes the google assistant on my phone, and it is piped via my speakers, etc.. A short press invokes speech actions via intellilink.
That just doubled my previously understood utility of the system.
Thought I would share. Again, if this is "old-hat", let's just call this an "early alzheimer's" moment. :rolleyes:
Andoid Marshmellow OS on the phone.
Yep, and with iPhones it'll trigger Siri hands free. [emoji106]
  • 2 months later...
How long is a long press? I read this a few days ago and tried it but was unsuccessful.
I just got my 2014 Sierra All Terrain a little over a week ago and I'm still learning on how to optimize as best i can.
Sent from my XT1254 using Tapatalk
    Dom Colussi
    Dom Colussi
  • Who's Online   3 Members, 0 Anonymous, 611 Guests (See full list)
