High Beams Wire color
Dies anyone know right offhand the color of the hot wire to the high beams on a 2005 Chevy Silverado?
THANK YOU
I believe the high beam wire color is either green or light green. Easy way to check is pull the headlight assembly out and look at the wires going to the high beam bulb.
Thanks arcade. Sorry I forgot to come back and thank you for the help.
Sent from my XT1254 using Tapatalk
    bellssn690
    bellssn690
  • Who's Online   2 Members, 0 Anonymous, 522 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
