5.3 help smoking
OK I have a 2000 Silverado 5.3 with a Paxton supercharger 2 weeks ago it started missing on all cylinders and white smoke coming out of oil cap and exhaust.so I changed the spark plugs and 02 sensors and still doing it. It dies use oil and it dies run a little rich at an idle. I'm lost I want to say is the piston rings but what would make all cylinders misfire
Pull the plugs.
Read the plugs.
Test compression.
Smoking out the oil fill cap doesn't bode well for the health of the motor...
You think head gasket or rings and if it was one of those why would it misfire on all cylinders I could see if it was one side. I did pull the spark plugs they looked normal besides one was a little dark
Pressure Test the cooling system most likely it has blown a head gasket. How long have you been running the supercharger?
    Patrick Fergy
    Patrick Fergy
  • Who's Online   2 Members, 0 Anonymous, 910 Guests (See full list)
