2011 Yukon power seat troubleshooting
My power drivers seat on my 2011 Yukon is malfunctioning and I'm hoping for some help to troubleshoot. The motor is not available as a replacement part and the dealer only sells the entire seat rail for +$600.
The motor will operate but is sluggish and stops after a few seconds of operation. The switch clicks regardless of the motor moving. The worm gear doesn't appear to be bound and moves when the motor operates. After recently moving the seat to the full forward position, the motor completely stopped working requiring manual movement of the seat to get it back to normal driving position. The power seat will work but slows and eventually stops even with the switch engaged.
I shot a quick video to capture the grinding noise:
This was taken from the floor looking under the seat with the worm gear on the left in the video frame.
Any advice is appreciated.
  • 3 weeks later...
Bump. Does this sounds like a bad/failing electrical seat motor for those with electrical motor experience?
  • 3 months later...
The seat motor on my 2011 GMC Sierra does the same thing. The back low to high function does the same thing as the video above. The front low to high function didn't move at all. I noticed the worm gear was moving. I opened up the little gear box and noticed the gear teeth were broken. I am pretty sure that is what is wrong with mine. I have found replacement one on eBay but seems expensive so I am currently looking for a cheaper alternative.
http://www.ebay.com/itm/291991330673
    bellssn690
    bellssn690
  • Who's Online   3 Members, 0 Anonymous, 636 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
