14 HID problems
FiveOH
OK so I know this has been covered but can't seem to find the solution short of retrofitting new projectors.
Recently installed new HIDs in my stock projector only to find out the output is horrible. It's like the point down and to the right. Is there anything to do short of aiming the entire projector? I feel like the projectors are in the correct spot bc they did decent with my halogen bulbs.
I tried contacting Phil (fast headlights) in reference to clearing my lights and new led drls but no response by business email. Kind of hate to spend the extra on retrofit if it will cost near what the 16 lights run. Should I just drop the cash and buy the 16s??
Technically you should change projectors when upgrading bulb type, however lots have just added HID without your problems. You should be able to adjust projector up and down but not left and right. (Note: the HID will output a lot more light to the sides by default)
I've been really pleased with my TRS HID kit. Bright and shines in most of the right places with stock projectors. My only remaining complaint with stock Sierra headlights is the lack of being able to see the curb when turning right.
So I figured out all I had to do was turn the drivers side bulb and put back in. It corrected the problem. Much more even light dispersion.
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 442 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
