Advice lifting rear 2½"
seansharley
After installing the Mcgauphy 7-9 kit set at 8" my rear is measuring 2½ low, I keep a lot of tools, and materials in my truck. Trying to decide add a leaf, air bags, bigger block. Would love to hear what others have done. Thank you
    zibzer2
    zibzer2
  • Who's Online   5 Members, 1 Anonymous, 805 Guests (See full list)
