04 3500 4l80e problem
I've got a 04 3500 with a 6.0 and 4l80e. The other day I parked the pickup and everything was fine. I tried to move it 30 minutes later and the transmission wouldn't do anything. I had no forward or reverse gears. So I winched it on a trailer(while in neutral) and brought it to the shop to try and figure out what was wrong.
While it was on the trailer one morning I decided to see if it would go into gear so I could unload it. To my suprise it would move. So I unloaded it off the trailer and drove it around a little to see how it would shift. Everything seemed normal. It shifted normal with no hard shifts between gears. The only problem I had was when I tried to manually shift. I put it in 1st and took off. When I got to roughly 3000rpm the trans. shifted to 2nd even though the shifter was in 1st. I stayed on the gas and as I got close to 3000rpm the trans. shifted to 3rd. I drove it back to the shop and cut it off. Cranked it back up a few minutes later and it wouldn't shift into gear.
I bought a code reader and it gave the code p1810. (Transmission manifold pressure switch) So I bought one and replaced it along with the internal wiring harness. Got everything back together but the pickup still won't move.
The indicator moves on the dash and the rpms fluctuate momentarily maybe 50 rpms when you go from park to reverse or drive.
I'm still getting p1810 even after changing the manifold pressure switch.
Does anybody have any ideas of what to check next?
    • Folks, Have a great new 2026 WT  (std cab, 2.7/4WD) w/base 40/20/40 mech adj bench "fake buckets"  (with lower and upper center console) heavy vinyl seats.  Overall the seats are very comfortable and the vinyl is heavy and appears less likely to 'split out'. Am very tall (6'5")  + a bad back/osteporosis/former hyperparathyroidism so ease/range of movement is a bit restricted.  The truck rides a bit high and I use a nerf step bar w/my left foot to step in, then I put right foot/leg in, drag my butt in  & get seated.  Worked fine in my 2018 RAM quadCab. But I end up dragging my butt over the left raised sidecushsion area of vinyl seat, and due to texture there's fair amount of traction on slide inward.  (ArmorAll didn't improve.) If the seat were even ~1/2" - 3/4" lower it'd be helpful, but base seats just have the forward/backward underseat bail and the side lever for tilt which really doesn't affect seat height.   I really don't want to 'de-puff' the left side sidecushion forming the  fake 'bucket'. I know one company sells 'seat elevator blocks':  but is there a simple way of lowering the height of the driver seat instead?   Thanks Bill W San Jose
    • I have a basic 2026 1500 WT  (2.7L/4WD reg cab shorttbed). Comfy, generally happy with electronics/radio - but is there a way I can add switches to steering wheel right-side position (curr. empty) so I can adjust volume, push phone button to voice dial, etc? Bill W San Jose
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
