Chrome windor traim and door handle swap
I am looking at swapping the chrome window trim out for a black set on my 2016, double cab. Before I pull the trigger, is anyone interested in swapping before I make the purchase?
Same goes for the door handles. I'd prefer to add color matched handles (Tungsten Metallic) but black might work as well.
PM or reply... Thanks
