Auxilliary Light Switch
rtshaw
post-164838-0-27636400-1478432005_thumb.jpgFirst, let me say what an awesome place this is to get answers to questions. In the past two weeks I have been able to: wire fog lights and high beams to come on together, find the correct wire to tie the lights on my side steps into, and find a good place to mount my rear facing Ridgid lights. What I could not find, was a good place to install a switch for those lights. I love the interior of these trucks and just could not bring myself to install what looked like an "add on." Every time at looked at the two cigarette lighter sockets I kept thinking that would be a great place to have switches instead. So I found one that fit inside it like a glove. I was able to cut the back of the socket off to accommodate wires and switch. Works like a charm!
I am currently doing the same modification and man its a pain in the ass running the wires and getting the 12v plug out but it will be worth it when its finished. I agree its a perfect place for a switch.
It's not to bad getting the 12 volt outlet out. There are two plastic tabs that you press, then you can slide the 12 volt outlet right out. Did mine about a year ago when I did my light bar.
    Sothpaw27
    Sothpaw27
  • Who's Online   5 Members, 0 Anonymous, 635 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
