No Crank, multiple lights on dash.
I've been searching & reading and am at a loss. I have a 2003 Silverado with the 5.3L and auto transmission.
Started on Wednesday, went to leave, everything powered up, no crank. Pulled battery, tested, it is good. Got under the truck, smacked starter with a hammer a few times, truck fired up. Worked fine the rest of the night and Thursday morning, but I decided to replace the starter. New starter in, first start is fine. Next start the starter keeps cranking after motor fires, shut off key, starter was still cranking. Pull that starter, go get a replacement. New starter installed, no crank.
Check all fuses, they are good. Test all relays, they are good. Key in crank position, no click on starter relay. Connect jumper wire to crank fuse "output", relay clicks, still no crank. Pull relay, jumper wire to relay output, starter cranks. Turn key to run position, jumper to relay output, motor cranks, fires and runs.
Now that it is running, I have the following lights staying on. Check Engine, Security, ABS & Brake. Driver information center says "Service Brake Booster".
I have reverse, 2nd & 3rd gear. When in "D", transmission is in 3rd, have to manually shift into 2nd to take off and then back to 3rd. If you floor it, it will not downshift on it's own.
I appreciate any help you can give.
You have a burnt BCM fuse. Check all the fuses. I believe it's a 60 amp square fuse in the underhood fuse block.
Coby7, only 60A square fuse is the ABS fuse.
I have the following other square fuses:
MBEC 1 - 50A
BLOWER - 40A
LBEC 2 - 50A
STUD #2* - 30A
IGN A - 40A
IGN B - 40A
LBEC 1 - 50A
All fuses appeared good. I will double check with an Ohm meter tomorrow.
Thanks for your reply/help.
Cody7,
Turned out to be the IGN A 40A fuse. Was a pain to figure out since fuse apparently had enough contact to test good on the Ohm meter, but not enough to pass current.
    CaptainDad
    CaptainDad
  • Who's Online   4 Members, 0 Anonymous, 394 Guests (See full list)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
