Lund Running Boards compatible?
rmanf150
As my user name would suggest i am more of a Ford fan =P ,but i am crossing enemy lines with good intentions haha.
My father in law just purchased his first brand new truck, and he got a hell of a good deal on a 2016 Silverado LT Extended cab.
Great looking truck, whatever chevy calls their dark blue it looks great. ( my F150 is Blue Jeans Metallic so i am bias). Only problem is it didn't come with running boards, and my mother in law has a rough time getting in. My wife and her sisters agree that getting the boards for them for Xmass was a great idea.
I found a set of Lund 24076005 on Amazon. Amazon compatibility checker said it would fit, but as i did further research, Lund only lists it being compatible from 99-13. These are Frame Mount, NOT body mount running boards. They bolt to the body mounts for the cab. Could anyone tell me if the body mount position changed between the 13 model year to the 14 model year, or if you think they will work, or if i should send them back?
Thanks in advance for any information that anyone can provide.
The frame changed completely in 2014 so I doubt the body mounts are in the same locations. I don't think they will fit.
    contrabombarde
    contrabombarde
  • Who's Online   3 Members, 0 Anonymous, 759 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
