2004 Silverado ABS Issues
I just replaced the 2 front abs sensors on my Silverado, my abs pulsated once in a while at low speeds and I decided to replace them due to that and age. After new replacements were put in I now get a slight abs pulse every low speed stop I make. And yes I did clean off the hub before installation.
What else could it be? There are no codes present. I searched around and haven't heard a similar scenario.
Thanks I advance
Are the wheel bearings nice and tight/no play? Clean mounting surfaces on the hub?
Yes my bearings are tight, the mounting surfaces were fairly clean and I cleaned them off more with a screwdriver. There was some but it surely wasn't very much. I'm not sure what is going on
Figured it out, removed senors again and ground down what I already thought was a clean surface, reinstalled and everything worked great.
    Selfman
    Selfman
  • Who's Online   3 Members, 0 Anonymous, 529 Guests (See full list)
