Question for all the peeps with the 4.3ecotec...
No idea what the honeycomb wheels are but I am running 20 in rims from a 2016 Denali. My overall MPG per tank as around 22-24 mpg, and that's mixed city/highway driving with me flooring it a lot. Keep in mind that I do have the lightest configuration possible as a 2WD single cab short bed.
  • 4 weeks later...
I had 20/8.5s wheels with 275/55/20 Goodyear SRA's and I stayed 19/22mpgs. Now down to 16mpg running 33/12.5 Toyo RTs with an offroad bumper.
