Tahoe Center Console Seat
Was wondering if anyone has a Tahoe w/ the Center Seat Console?
The one that folds up and has cup holders.
Would like to know part number.
Did a search didnt come up w/ anything and dealer told me 'its not avail' :D
Thank you
John
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
