Turn Key Engine Supply
gmfan24
If you have 2 weeks and some extra cash to waste, order something from Turn Key Engine Supply. They will charge you, email you an invoice, not fill your order, not reply to emails, not answer their phones (I tried every extension), then say "**** off weirdo" when you call them out on their own contact form. The whole email is in my post Bargain Week. Vendors like this are why my supercharger is still sitting on the table.
