Dome Light not working / Passenger door only !
Howdy Gents,
Where is the damn switch that activates the dome light when the passenger door is opened?
Everything works as designed with the over ride switch, drivers door, etc, etc.
It's only when the passenger door is open that the dome light dose not come on.
I know it's really no big deal but it's driving me nut ! LOL
2003 Silverado 4x4 Ext.Cab
Never mind, Did a little investigative work.
Located the switch which i found out is incorporated in with the Power Door Lock Actuator !
The lock works so I'm not replacing it because of a light not working
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
